Hello from Chehire
claynut4
Northwich
Just put a deposit on a Focus Jam2 6.8. Don't know if I can get straight to it. The 6.8 comes with a Kiox display that i dont want, I will change this to a Purion, there a couple for sale on Amazon but the modes are Eco, tour, sport and Turbo, does anyone know if it picks these up from the motor, or are they hardwired into the dispaly as EMTB mode is not listed in the discription. Thanks
Jackware
Fat-tyred Freakazoid
2,188
2,393
Lancashire
Hi
I suspect the seller on Amazon may not be using the latest image or info as the eMTB mode is part of the motor firmware. Also there are cheaper UK suppliers showing in Google than the price I can see on Amazon?
Davidwylie
76
63
Leicestershire
Thanks for the information. Do you know if these things are straight forward to swap out?
Just one wire plugged into the motor and it all works right off. Only issue is the wire routing, on my Trek Rail i had to drop the motor to feed the wire (not a problem, just 6 bolts ) I changed the other way, I went from Purion to Kiox so I have a Purion laying around collecting dust.
577K
