Headset
Yorkshirelad
144
74
Robin hoods bay
I’m pretty sure I’m just being an eejit but here goes.....
Fell off the other day and the headset cup has twisted round in the frame meaning the block lock thing is offset, now I can only turn the bars slightly one way, and all the way round tother.....
im paranoid about using my normal method (?) of removing the headset cup from the frame as I don’t want to damage the carbon, do I need to use a special tool? Never had a carbon frame before....
Fatbap
153
150
Rhondda south wales
No tools needed mate they do move
Just give the bars a tug in the opposite direction hit them back in line
Mine a my mates was out of line from new
  • Like
Reactions: rb.
Fatbap
153
150
Rhondda south wales
That sucks dude hope u get it sorted. I can’t comment on changing the head set on it as mine is mint an ain’t done 1 on a decoy before. I’d say it’s the same as others but u never know
OllieT90
Oxford
I have had this issue several times on my Decoy, you can easily drift the bottom bearing out using this tool;
RT-1 Headset and Bottom Bracket Cup Remover | Park Tool
Basically the larger diameter drift most tool companies make, i struggled to get mine to rotate back the first time so removed it and applied a decent amount of grease to the mating surface, subsequent misalingments can then be solved by banging the handlbars against the stop to straighten. YT dont use much grease from factory so the surface between frame and bearing drys out meaning it required huge force to move the internal bearing.
Yorkshirelad
144
74
Robin hoods bay
Yeah this is what I am going to have to do, so you drift out the full headset bottom cup, then press it back in at the right orientation?
Thanks for the help!
if anyone is wondering the lower bearing size is 40x52x7 r1
552K
