Levo Gen 2 Headset bearing for Levo 2020
beerglass
42
11
Bristol
In the manual it states 1-1/8" (41.8mm x 30.5 x 8mm, 45x45°) Campagnolo Standard compatible upper bearing and a 1.5" (52mm x 40 x 7mm, 45x45°) lower bearing
Anyone know where to buy these bearings from please
6,539
5,021
Check out Edgesportsuk.com. Note you need upper bearing with 30.5 internal diameter not 30.1. Bottom bearing is easier to find. It's basically IS 42 standard top and IS 52 bottom....but heights vary!
6,539
5,021
Use the Specialized Headset Selector on the site to select the correct top and bottom bearing rather than look for a set.
6,539
5,021
Or simplybearings.co.uk for a bigger choice of quality. E.g upper bearing £13 or £40! There are also 2 versions...take a look at yours to see if it has an extended lip on the inner chamber or not. They have both versions.
Bumpy
50
21
Bristol
you said TH 070 originally!
Yes because after putting my numbers in their website that's what Kinetic crossed them over too. They arrived and they are FSA bearings TH070 and TH870E. I did state "which then crosses over to what I said."
Perry01
23
15
Like the OP, I also need replacement headset bearings for my Levo.
Manual says :”1-1/8" (41.8mm x 30.5 x 8mm, 45x45°) Campagnolo Standard compatible upper bearing and a 1.5" (52mm x 40 x 7mm, 45x45°) lower bearing”
Will the FSA TH070 front and and TH870E rear be compatible?
MrSimmo
1,096
1,047
The Trail.
Following up on this as I bought a set of replacement bearings from Kinetic bearings. I paid for next day delivery but they never arrived, customer service told me I needed to wait as I had only paid for next day not guaranteed next day.
I ended up giving up and buying from my LBS who got an official Specialized (FSA) kit in for me within 24 hours and it only cost £2 more than the other route (£24 inc shipping for Kinetic vs £26 for Specialized). The OEM kit has the top cap and a spare bottom ring included as well.
Not Kinetics fault but worth considering that you may be able to source the OEM kit for similar prices and avoid the Royal Mail hassle.
553K
