¿Alguien ha puesto una horquilla de 150 mm en Neuron ON?
franciscoasismm Active member May 31, 2021 244 252 Badajoz May 31, 2021 #1 ¿Alguien ha puesto una horquilla de 150 mm en Neuron ON?
J Jacques42 New Member Jul 15, 2022 1 0 Xyz Jul 16, 2022 #2 Hey - I did not do that yet but I am considering. Did you make it happen ? If so, any advice and experience you can share ? Any particular shockers you’d recommend ? thanks a million!
franciscoasismm Active member May 31, 2021 244 252 Badajoz Jul 16, 2022 Thread starter #3 I'm still thinking about it, I found this video that says that if you can, it's in Spanish. Greetings.
franciscoasismm Active member May 31, 2021 244 252 Badajoz Feb 11, 2023 Thread starter #4 Este viernes le puse horquilla Yaris 150 mm 51 offset, sube mejor, baja mucho mejor. Su comportamiento es muy similar al del Spectral ON 2018. Last edited: Feb 11, 2023
