Has anyone got one of these?
9,367
The actual lever for a Shimano XT left hand brake lever assembly. The Shimano ID number for the assembly is BL-M8100-L
I had an off, climbing something too steep, fell of backwards and sideways and bent the lever. It snapped when I tried to straighten it. The LBS couldn't get one (the pandemic was in full flow). Before I try again, does anyone have a broken lever assembly with an intact lever that they are prepared to send my way? :)
Unfortunately, the lever has to be from that actual item (BL-M8100-L), earlier ones are thicker and won't fit. Not sure about later ones.
Fingers crossed! (y)
Base
27
14
Toronto
I found out you can buy either a right or left lever member as long as the spring works as that is the only thing that seperates them from being a L or R. At least with my SLX lever I had to replace.
554K
