Dholbrooke82
I have a leak from the damper side on my 2019 marzocchi bomber Z1 forks. Thinking it was probably a damaged crush washer I did a lower leg service but after reassembling I still have a serious leak coming from GRIP damper. Having never done a rebuild on the damper I'm wondering if anyone has any advice on the rebuild and what they think the issue could be/why it is leaking so much fluid. Do you guys think buying the rebuild kit and rebuilding will fix the issue or could it be something more serious? The leak appears to be coming straight out of the rebound adjuster.
