Glazed pads
robert
162
14
scotland
My rear Shimano resin brake pads keep glazing, iv cleaned , filed, burned them they seem to work fine after that for one ride, this problem has just occurred iv had the same brake for 4 years, I do drag my brakes when riding but iv always done this only recently this problem has arisen, would changing to sintered help ?
9,251
Four years of dragging, filing, and burning! I'm surprised that you are not down to the metal backing pad!
If they have lasted four years and only now giving problems, it must be time to change them for more of the same. The old ones don't owe you anything. :)
robert
162
14
scotland
robert
162
14
scotland
The brakes have lasted 4 years the problem with the pads is recent, iv rode dragging the brakes for years and never had any pads glaze.
9,251
They are probably worn out. Have you checked how much pad thickness is left. The guides say change at 1 mm thickness, but I always go below that. I wonder if the pad material close to the backing plate is altered by the process of bonding to the backing plate? Anyone know for sure?
outerlimits
E*POWAH BOSS
1,241
1,575
Sandpaper them on a flat surface, clean with isopropyl alcohol, dry over a gas flame, blow out like a candle.
Sand the rotors to roughen up and clean with isopropyl alcohol. Fit pads and bed in.
Also tighten your rotor bolts and caliper bolts.
After 4 years the rotor may be too far worn. Exposed edge could be rubbing on the pad spring.
551K
