UnreasonableMuppet
I've been hearing creaking noises while pedaling hard. After checking my motor mount bolts and finding them well tight, I noticed some up and down play in the drive side crank.
I pulled the motor to investigate further.
The point of the screwdriver indicates where I am feeling play. It isn't a lot of play, and there's no spec that I can find for allowable play. The play is happening between the clutch hub and pedal axle. There's no play that I can detect in the larger clutch hub bearing.
I know that side to side play is expected (up to 1mm), but I have no info about up and down play. I don't find any play in any of the other bearings, and everything rotates smoothly.
The clutch hub is circled on this parts diagram. The only replaceable part shown on the parts diagram for the clutch hub is an oil seal and o-ring. The oil seal is not sold separate from the clutch hub. I do find the clutch hub listed as available from several US yamaha parts suppliers.
Here's the clutch hub in a tear down video:
Does anyone know if there is a bearing that can be replaced in the clutch hub? How much play is acceptable?
