Giant led 1 battery issue
simonk
SLayer ?
Jan 27, 2020
337
423
Exeter
According to the manual that represents ‘battery issues’ (page 21).
Have you done a system scan from the app?
Max333
Lithuania
yes i,ve read the manual , but it doesn,t make any sense. What app do you use ?i,ve given the bicycle for repair , and the owner said that the battery is fully working and the problem is somewhere else.
Max333
Lithuania
LED signals there is a battery issue which has 2 main causes:
  1. Fitment: The battery isn't properly aligned and snug. Battery error from Trance? - EMTB Forums
  2. Dirty contact points: Clean the pins and insert points with a cloth and isopropyl alcohol
If the problem persists then you'll need to go back to the shop
thank you for the answer , but i think they didnt find out what was the problem in that forum because he had two lights flashing .
551K
