Hi Newbie here,
Giant DPS-83CB A 41.8 v @ 2A
I have a Red flashing led .. no charge to battery !
Can anyone help with the functionality of the wires 5 way Neutrik connector.
I have tested the :- ( Charger plugged in & On ..)
Pin 1 = 34.5 vdc Brown 1mm sqd wire Main + to battery .
Pin 2 = 34.0 vdc White 0.5 mm sqd wire unknown function?
Pin 3 = 4.0 vdc Org 0.5mm sqd wire function unknown?
Pin 4 = GND Black 1mm sqd wire is the Main zero volts ( GND)
Pin 5 = 4.6 vdc Red 0.5mm sqd wire function unknown?
I’ m trying to diagnose if the BMS is not “ handshaking “ correctly to Turn on the main supply voltage out of the charger ?
Any steer on this would be greatly appreciated.
Derrick
Can provide further information on this issue.
Derrick
