Levo Gen 3 Gen 3 Levo Comp rear shock no LSR adjustment-no blue dial.
Ewor
Newbury
Recently took delivery of 2022 Levo comp. I’ve been fine tuning my suspension setup specifically the standard rear shock (FOX FLOAT X Performance) on my new Levo. I was expecting a Low Speed Compression adjustment (blue dial when I look at fox website). Instead my shock seems to have a black blanking cap which is fixed. but has the red dial for rebound adjustment. Is this normal on comps? Or is there a component shortage and I have some weird hybrid?
Repsol
189
81
Yorkshire
Mines the same on my comp carbon 2022. The S1 frame size gets the Fox Float DPS Performance Elite, 3- position adjustment.
6,536
5,021
lower cost OEM version only.
Good news is you probably do not need LSC adjustment as long as the shock is tuned well. I have the factory version on my bike and my settings all 4 adjustments ( LSC/HSC/LSR/HSR) are at ,or very close to Fox recommendations, and I have not needed to modify since the first couple of weeks of riding with it.
553K
