KenGPS
I have a new 2021 Levo Comp. I've set the sag properly front to back, and high enough pressure not to bottom out on jumps. On jumps I use 95% front, 90% rear. But on smaller bumpy sections of trail I am using about 40 percent of the travel limit in front, and about 60% in back. I'm thinking I should add some volume spacers in the front fork. That should allow me to lower the pressure in the fork and get closer to the same 60% travel range same as the rear suspension, yet without bottoming on the jumps. But I'm wondering if there is any reason I shouldn't match up the front to rear suspension. As it is I'm basically riding with the front high all the time, and the rear sagging a bit lower. Is this desirable for some reason? Or should the bike be riding evenly whether small bumps or large jumps? Any help appreciated.
