From Scale 970 to LightCarbon LCE39
nikolajandreasen
DK
Hi everyone! 😁
As my post in: Newbies Hangout says, I'm relatively new to the MTB world, but I've fallen in love with it. I am a trained electrician, and educated marine engineer, so fiddling with tools and getting greasy is not unknown to me.
But this is the first time I have to assemble a MTB bike from scratch. (If I jump into it).
My current bike is a Scott Scale 970, and thinking about (If possible) to build a LightCarbon LCE39 with M560 where I would like to recycle as much as possible from my Scale 970, which has the following components:
  • Fork: RockShox Judy Silver TK Solo Air with SCOTT RideLoc Remote
  • Stem: Syncros Alloy 6061 - Oversized 31.8mm - 1 1/8" - 6° angle
  • Back Shifter: SRAM NX Eagle
  • Shifter: SRAM SX Eagle Trigger
  • Gear group: SRAM SX Eagle
  • Cassette: SRAM SX-PG1210, 11-50 T
  • Crank: SRAM SRAM SX Eagle DUB Boost, 32T
  • Front brakes: Shimano MT200
  • Lever:BL-MT200
  • Rear brakes: Shimano MT200
  • Lever: BL-MT200
  • Rim: Syncros / 32H
Is these be alright parts to recycle, and take the jump into E-MTB? As for brakes, I'm thinking of using the adapter for the 180mm disc so that it is compatible with the frame from LightCarbon.
Hope you guys can help me. 🤞
nikolajandreasen
DK
JimLee-Lightcarbon
Lightcarbon
Apr 15, 2022
289
320
Amoy
I can see I was a bit too fast last night, when i was on the mobile
I have looked through the specs for the LCE39 on the computer and can see my brake system and fork are not compatible.
I have therefore looked at the following components:
Could that be alright?
front fork 150-160mm, tapered
Disc 180mm, or 203mm with adapter,
rear shock 190*51 standard mount with , if you use the one size 185*55mm, need you buy the bolt to fix it, our bolt fit fro 190*51mm standard,
your groupset is ok
552K
