I have been using tape from Bike Tart for years now and I have seen no discolouration at all, didn't even know it was a thing.
Invisible Bike Frame Protection
I use the 75mm wide, any larger and I found it tricky to handle. That stuff is not like folding pasted wallpaper, it sticks to itself permanently!
Have a hair drier handy to apply to hydro-formed sections, also for removal.
Definitely recommend Invisiframe kit , really good protection which pretty much covers the whole frame. Depends on frame size though as they only had medium kits in stock and I needed a large frame kit for Focus jam2 plus 6.7. They offered to produce one ,but wanted my frame for sizing, I didn’t accept the offer as would of been about 2-3 weeks ( due to work load ) with out my new bike . So I ordered the medium kit and modified where needed. To be honest only the top of seat tube and top of head tube that came up a bit short .What if any frame protection are people using on Jam2? Normally use generic helicopter tape on clockwork bike but discolours after 6-8 months.
Looking at invisiframe but damm expensive if you get lbs to fit it.
15cm wide and 2m long @ 40 pounds, jeez that ain't cheap and 15cm wide would be a nightmare to play with.
That is why I recommended the 7.5cm wide (I said 75mm, same thing). 2m of 7.5cm will do all the danger areas on a bike. I have never needed more.
I have a 2-page guide to applying bike tape. It was constructed over time with the help of other riders who provided their tips and good ideas. if you send me a private message with your email address, I will email you a copy. Free of charge of course!
I wouldn't try to use 15cm width either, 7.5cm is tricky enough as it is.They only have 15cm available now which is way too wide to play with to fit to a bike.
