Legendary-dave
Hello , after the stock shock on my levo failed and was beyond repair ( lasted 3 years ) …I upgraded to the fox x2 , on the box it says it’s a 2023 model shock …. I set it up with 2 volume spacers and set the air pressure to the guided recommended psi for my weight , had a flat quick blast down a fire road just to test it out , didn’t ride again for three weeks and noticed when I got on it the sag was massive so took it easy on the ride , got home checked the pressure and I had lost 50 psi ….. pumped it up again to 230psi and then checked again next day 24hrs and same thing ….. lost 50psi …… it didn’t increase so I’m thinking or hoping that it isn’t a warranty issue but something I’ve not done ….. any ideas or guidelines would be good
