diogo282828
Hello there,
I've just upgrade my shock to a fox float x2 2021. ( Turbo Levo 2020 Comp)
Need a bit of help with it.
I dialed in the settings on the shock exactly per fox recommended setup. 210 psi for a 25%sag, I'm 158lbs/72kg. The shock behaves in the initial part of the stroke strangely, or at least very differently than my rockshox that came with the bike. There's a noticeable bump/harshness, It's like there s a groove that the shock needs to overcome in the beginning of the stroke. Pedaling through flat trails with roots and rocks the bike give this bumpinesss to the stroke. It's sort of threshold it n overcomes the come into the nice part of the stroke. I thought the shock was completely off, maybe faulty. I backed the low speed compression and rebound all the way, and it disappears. Right now I have 2 clocks of compression and rebound. I can still feel the bump slightly. High speed is per fox settings and I'm OK with it. 2 volume spacers. So long story short, is this feeling normal? It doesn't feel it. It's very weird. Give me your feedback guys.
Having a har time finding info on this shock for emtb. Thank you.
(Iv'e posted this oon the Specialized forum, but I think it belongs here)
