Fox Transfer dropper post getting sticky
Snoozeboy
104
56
Lausanne
I've had a Fox Transfer dropper post for around 4 months.
Originally, it worked well, but now it's noticeably slow to pop back to the extended position. it often fails to make it the last inch, which means I have to take my other hand off the handlebars and nudge it. Annoying.
I haven't done any maintenance on it yet, except for wiping it down after each ride.
What do I do? Claim a service on warranty or should I try and service it myself?
ScottWest
126
76
Oregon
My '19 did this. I sent it back for warranty service. Does it function in the same way off of the bike?
Snoozeboy
104
56
Lausanne
Thanks for your advice.
I didn't take it off the bike yet. I didn't want to fiddle with the cables if people on here just advise me to claim a service on warranty. I don't think it's an issue with the clamp being too tight, if that's what you're asking, as I haven't changed the tension on the seat post clamp since it was installed.
KennyB
824
564
Taunton
I had similar a few months into ownership. It was the seat clamp too tight. I adjusted it to 4Nm, from 6, and the post didn't stay up. I then used carbon fibre assembly paste and job done. May be worth checking the manual?
Snoozeboy
104
56
Lausanne
Thanks for your reply. I will check the manual. I have to find it online, because the LBS didn't give me any information when they installed it.
I had this happen to mine, it would get stuck in the position it was raised too, and not return to full height unless fully depressed again.
Silverfish warrantied it , no problems since, they said wasn't enough grease/lubrication out of the factory in it. Their turnaround was about a week form recollection
Fox Warranty Claim Registration Form | Silverfish UK
578K
