Answered Fox Factory 34 Axle Adjustment
Woad
7
Utah
I have a new Fox Factory 34 fit4 fork. The quick release is too loose and I can't get it tight enough. On all my other forks their is a Numbered Cam adjustment on the other side of the skewer that you can adjust to get more tension on the axle. The factory doesn't have this, and it's just a 3 pronged cam, that can't be adjusted. I can't find any literature online about this issue, and the manual just shows the numbered cam's like the other forks.
RickBullotta
1,871
1,604
You have the same thing - just without the numbers. Loosen the bolt, rotate the notched and threaded piece clockwise or counterclockwise as needed.
Woad
7
Utah
Thanks for the quick reply, thats what I thought as well so I tried tightening it up after rotating it and marred the surface of the 3 teeth. I took a better picture. You can see that there is no way I can adjust it because in the end, The cam has to line up perfectly with the 3 teeth in the fork.
Thanks for the help, i feel defeated by this blasted thing!
576K
