deanFBM
I'm running a fox 36 e-bike chassis on my normal bike, 29" @140mm.
This uses a smaller diameter air piston than a normal for 36, the air shaft assemblies from a fox 34 in fact, so I'd expect required pressure to be a bit greater than that in a normal fox 36, more in line with a fox 34.
Crux of it is both the 34 and 36 charts recommended about 100psi for my weight, I'm at 140psi to get 15%, this is above max recommended.
Similar story for others?
