DariuszHoryd
Hello, anybody can tell me, that change rear damper from factory Float DPS 185x52,5 to DPX2 185x55 will affect any big problems ? My bike is Giant Trance E+2 Pro 2019... ?
I just bought the DPX2 shock and can't wait to see the difference vs the regular DPS shock. Hoping to get more small bump compliance from it. Your rig looks great!So ... I changed dps to dpx2 with extra 2,5mm travel. Test ride in next fiew days, after full bike rebuild (new Fox 36 Performance, and mullet DT H1700 wheelset and SLX brakes).
Have you tested yours yet? I installed my DPX2 and the rebound tune feels pretty light even at fully closed... not sure if it's just valved so it still feels relatively open at low speed. The DPS feels considerably slower (rebound).So ... I changed dps to dpx2 with extra 2,5mm travel. Test ride in next fiew days, after full bike rebuild (new Fox 36 Performance, and mullet DT H1700 wheelset and SLX brakes).
Not yet pal. I did not have enough time to finish my bike upgrade... and done it yesterday.... so maybe I the next fiew days I'll tell You more.Have you tested yours yet? I installed my DPX2 and the rebound tune feels pretty light even at fully closed... not sure if it's just valved so it still feels relatively open at low speed. The DPS feels considerably slower (rebound).
Yeah You're right... guy who selling me dpx2 told the same, that heat management for DPX2 will be far more better on longer trips. About tune, I have some tokens for front 36 and rear and after a couple of rides I will find, that need to be change or not.DPS to DPX2 is just a cooling ability upgrade. My DPS after a couple runs would just start to feel like a spring. Only thing that will get the shock to feel different other than handling heat would be different tune and different amount of air spacers.
yep, but I used a DVO coil with a much smaller reservoir.......longer res like on a marzocchi bomber will interfere in full compressionI know this is an old thread, but any of you did this 185×55 upgrade on a 29" trance?
Thanks for the reply. So you're saying it was interfering (see attached) on the revervoir and not the rear wheel in the seat tube?yep, but I used a DVO coil with a much smaller reservoir.......longer res like on a marzocchi bomber will interfere in full compression
Do you just fully remove the air to check interference?Yes exactly...not sure what reservoirs will fit but the longer one I tried on the Bomber definitely interfered. Also frame sizes might come into play......mine was a small....and extra large might clear??
I used the Jade X Coil.....you could also use the new Topaz with the horizontal reservoir.
Topaz Gen 3 – DVO Suspension
dvosuspension.com
yeah, or for a coil pull the coil spring off and fully compress the damper onlyDo you just fully remove the air to check interference?
