Tedgar
I did search this and came up empty. I have a 2019 Levo Carb Comp with 34 Fox Rhythm series Float, Grip 29. Code DKNF
What I think I know: Book says max travel is 160mm. I can increase travel by changing to a 160mm air shaft. 34mm Ebike forks use 32mm air shaft.
What I don't know: What air shaft do I need (specific part number as I assume there are hundreds of different ones)? Ridefox does not list one I can find in 29" fork.
Thanks for the help.
