johnscioscia
How high can I go on Stem Fork riser on my Levo and still keep the swat tool. Attachwed are the 2 different things Ive been playing around with. The variable one works great and I have no problems there. BUT Id rather use a straight up stem fork riser like the one pictured. I tried. I DID get it to go on but then the stabilizing screw "not sure what that is called" wasnt long enough to meet the nut at the base of the fork. Any ideas?? Am I limited to ONLY the adjustable one which as I say works great but looks dorky. I also have a diety anodized blue triple clamp Id love to use but I cant with the variable stem roser whereas I could with just a straight riser like the one in the pictures attached. I already have 80 mm bars from Diety so I dont need any advice there. I know Im going quite high but Im 60 plus and need the bars up high. Thanks Perhaps to go with straight stem I just need to go shorter my guess?? OR can I get a longer bolt screrw nut set up "The one I dont know what it is called but hold evrything tight. Thanks!! One other thing, With the staight one on I noticed my swat tool was too wide to slide down into the fork tube!!! Are there wider ones? , gotta be right??
