Fork Pressure
Bomble
661
386
Yorkshire
Just changed the travel on my Zeb's, followed Rob's excellent video. Like Rob i've dropped from 170 to 160, would my preferred psi at 170 work the same at 160.
Obviously i'll find out when i ride it but just for initial setup i thought i'd check.
Mcharza
E*POWAH BOSS
Aug 10, 2018
2,615
5,378
Helsinki, Finland
Your initial setup should be setting the sag right. After that adjust compression and rebound.
Then test ride it.
If you don't like it drop or increase pressure. Remember adjust rebound and compression after that.
Bomble
661
386
Yorkshire
The issue with that is that when it was 170 at correct sag the fork was terrible, stiff and harsh how ever I set it up. I ended up running it with a lot less air in it and it was great at weekend so kind of wanted to keep that feel.
Anyway I put in the same psi and tried the 160 tonight. It was too soft so ended up with 10psi extra and it feels loads better and is super plush. Weirdly the whole fork feels better whatever I change so I assume I’ve inadvertently fixed something😀
I’ll try it out later this week at the correct sag to see how it feels. It felt awesome tonight but I didn’t get time to check the sag.
apac
1,326
1,173
S.Wales
It doesn't matter what your air pressure gauge says, It's all about getting the right percentage of sag on ALL air spring suspension. The extra knobs n dials are just little finishing touches to be done After you get the sag as you want it.
i dont want to teach grandma to suck eggs, but are you slowly compressing the fork a bit as you pump it up to get equalised air chambers? Or matbe you don't need to do that on a fancy Zeb🤔
Mcharza
E*POWAH BOSS
Aug 10, 2018
2,615
5,378
Helsinki, Finland
Maybe you accidentally equalised air chambers :D
But as @apac wrote remember to do that maybe after every 50 psi
PAC
21
31
Billings, Montana, USA
Do you have a link to the video?
554K
