Answered Fork Choice
mas
60
35
Bought a Merida eone sixty ltd edition with a Rockshox 35 Gold which I am looking to upgrade as it doesnt feel that great. For under $1000 AUD the choices are:
- Fox 36 second hand
- Rockshox Ultimate second hand
- Suntour Durolux RC2 New
- Marzocchi Z1 Second hand
I liked the grip damper on my old fork which the Marz has and the 8000 model above my bike has the Marz Z1 but it says it is ebike specific, which the above one isnt, and I cant find any info on their website about what that means.
Which would you get and why?
MAS
Lem
Hi Maz,
I also purchased a bike (GT sensor Carbon) with the 35 Gold which i didn't think was that great, had a awful lot of stiction. I have since replaced with a Durolux RC2 which I found to be a excellent fork. I have a older FOX 36 RCL FIT fork on another bike and I find durolux is stiffer, better dampened and a little more supple. Just be sure get the correct negative spring for your weight if you get the non EQ version.
Before purchase I had also demoed some bikes, one with 2020 fox 36 grip and the other Z1, unfortunately not back to back with the Durolux but from memory Id say the durolux has comparable performance to the 36 Grip.
You can also do a service with only a 250mm adjustable wrench (however i would recommend getting a torque wrench) which is a plus.
I'd stay away from second hand FOX/RS products as the CSUs can creak and you wont be covered by the manufacture.
If you go the durolux and add anything extra to your cart free shipping (orders over $450) will disappear, if this happens just email sales and they'll give you a refund.
Hope that helps
cheers
lem
Lem
Can you get DVO suspension in OZ?
Yes you Can, here
You can also buy direct from DVO, You'll likely pay a bit more for shipping and what not.
I myself have a Topaz rear, its been great!
mas
60
35
Hi Maz,
Hope that helps
cheers
lem
Thanks for the reply Lem. I was so close to getting the Durolux but actually ended up going with the Marz Z1 as it was brand new and a little cheaper. It is significantly better than the 35 but am now thinking about converting it to coil.
552K
