KVDB
I needed to replace the internal battery on my Focus Jam2 2018 (E8000) as the internal battery was broken (see the full thread here).
After replacing the battery I found out to my surprise that the system doesn't work anymore in combination with the TEC pack.
-The system is working OK without the TEC pack connected
-Once I connect the TEC pack, the LED light on the on/off button of the bike is not turning blue, and the display is not coming on.
-The TEC pack is fully charged
-I've cleaned the ports with contact spray, but I doubt if weak connections are the issue anyway, as the TEC pack was working fine before the internal battery replacement.
It looks like the system recognises that the TEC pack is connected (otherwise it would start the system from the internal battery), but strangely enough the system is not turning on. It looks like that the TEC pack is somehow not compatible with the new version of the battery that I bought (although it's 'model-wise' the same battery, and originally Focus, but maybe just a newer version), or maybe I'm simply overlooking something else?
Did anybody experience a similar issue with the TEC pack? (especially after changing the internal battery)? It would be a joke in case it's indeed a compatibility issue, and I'm not able to use the TEC pack anymore...
