My jam main bottom suspension pivot is seriously f***d. Bearings knackered, possible frame damage. Problem I have is that the main thru pivot axle will not come out. Its a hollow pivot with a conical tension cap on none drive side. Cap comes off but the thru pivot will not move, apparently it should just drop out. I've applied WD40 then partially inserted tension cap bolt most of the way so there is a small gap then gently tapped that
end to try and free it, but no joy. Also tried freeze release spray. I think pivot axle must be seized onto one or both bearings.
Anyone got helpful advice?
