Flyon twin tail lights fitting
Mike5705
13
North Yorkshire
Hi has anyone fitted the twin tail lights to their flyon yet?
Its supposed to be pre wired but i am a bit reluctant to prise off the blank plates in case they are attached to something. Thanks
Jackware
Fat-tyred Freakazoid
2,058
2,261
Lancashire
Or do you remove these side covers to access the tiny securing bolt?
Mike5705
13
North Yorkshire
Hi thanks for that.The picture shows a securing bolt..Mine doesn't seem to have any threads on it, i just thought it was a positioning guide.
Jackware
2,058
2,261
Lancashire
I can't see what else would stop it falling off? Presumably the current blanking pieces are held in the same way and the bolt will cut it's thread?
Steve h
24
12
Chalford
I’ve fitted these to mine, yep the wires are in the frame ready to connect. They are secured with a small alan bolt. Very fiddly to get the bolt in! I ended up cutting a alan key down so that the short leg was very short.
Mike5705
13
North Yorkshire
Hi Thanks for the help.. I fitted the lights today.. its a bit fiddly especially trying to get the retaining washer back on.
Here are a couple of photos i took..hope it helps someone
Cobra
7
7
Norway
Not the right connectors in display, guess it should be connected above motor but then you’ll need an exstension cord!
Cobra
7
7
Norway
I have located the connector for the Skybeamer!
The connector works as a loop when Skybeamer isn't fitted and you need to pull the cabel out of the frame and unplug connector.
It's covered in a fabric sleeve ziptied. Cut ziptie on one side and see if connectors match with Skybeamer. If you cut wrong ziptie you will see the connector for the display and it has a round connector.
Cobra
7
7
Norway
Cabel 2 and 5 are connected in a loop, when you disconnect only one will fit Skybeamer connector. The female connector will be unused!
Mike5705
13
North Yorkshire
Thanks, i have had a look at those connectors but i was looking for a spare slot. Is everything else working ok? just seems odd to have it connected in a loop
Cobra
7
7
Norway
Yeah the loop got me confused to but now everything works just fine!
Hairy bum
54
14
Uk
Oh poop
I’ve hit a snag :oops: I’ve got a small blue plug on mine … any ideas where to plug it in ?
552K
