Airz
Anyone else getting this on their Fox DPX2 shock? Seems to be holding pressure at 280psi but I get the fluid build up around the sag o-ring after each ride. It only seems to have started doing this the last couple of rides however I did need to add pressure to take it from 250 to 280 so wonder if that has highlighted a weak seal.
I already have a sleeve service kit for it that I bought last year so wonder if this is just a sleeve service needed or whether it needs a full strip down as I have done 400 miles on it now.
