Fats or Studs? which are best for winter riding?
daju
134
86
manchester by the sea, ma
Today with 2" of fresh in New England fat tires might have helped me up on steep hills that I spun out on with the 45 North studded tires. But that would mean an entirely different bike. Can anyone tempt me with a great fat tire electric bike?
And we only have deep soft snow for a few days a year here....
Mabman
1,124
1,851
Oregon USA
What psi are you running? At that depth you shouldn't need fat tires IMNSHO just go as low as you think you might be able to get away with, tubeless will help/ Studs help on ice and slick roots but don't have much effect on actual snow I've found.
Stihldog
Handheld Power Tool
3,494
4,872
Coquitlam, BC
This week I was wishing I had the fat tire. Again I headed up a slushy-snowy double track that turned into a 15% grade. In my last few meters I looked like a snake trying to go up a waterfall. Peddle assist helped and my rapid steering kept me vertical …for a while.
There are other trail options here and the snow melts quickly (sometimes). If I had to plough thru snow on a regular basis I suppose I could justify a fat bike or fat tire.
RickBullotta
1,846
1,578
Fat tires with studs. ;-)
When the snow is deeper, I ride my fat bike with 26" x 4.6" studded tires at around 4-5 psi. When it's not as deep but still icy in spots I run 27.5 x 3.0" studded tires on my regular bike or eMTB at around 8-12 psi.
RickBullotta
1,846
1,578
But man are they awesome on ice and roots...
I do notice that riding studs on rock and frozen dirt usually results in a few missing studs.
daju
134
86
Point well taken. The 45 North tires are (I'm pretty sure) not tubeless compatible so I'm running the lowest pressure I dare put in the tubes--about 28psi
CRFan1
173
142
NW Indiana
Fat tire bikes are fun all year round, not just for the snow! The grip they offer is outstanding. :)
RickBullotta
1,846
1,578
Good to know. Thanks
And the answer to the original question is
And a whiskey flask holder on your Fatbike.
hogicid
56
9
United States
View attachment 51458 View attachment 51459
There are other trail options here Fat Tire Electric Bike and the snow melts quickly (sometimes). If I had to plough thru snow on a regular basis I suppose I could justify a fat bike or fat tire.
Hello. What is the best brand fat tire e bike for salt water beaches
Mabman
1,124
1,851
Oregon USA
As someone that has ridden many miles of Ocean beach and never owned a fat bike I am not going to be able to give you an answer. However note that while a fat tire bike can outperform a narrower tired bike in the soft sand above the tide line it also is wildly inefficient at doing so and 99% of the time you will be seeking the harder sand below the high tide line and keeping an eye on the tide book to ride at or on a lowering tide so you can ride the harder packed sand which can mostly be ridden on any size tire.
553K
