Fathom E+2 Pro replace rear brake hose
KuRi
376
186
Spain
Hi!
I would like to upgrade my brakes. Do you have a video or tutorial on replacing rear brake hose with the high performance shimano hose? It looks easy to me, but I tried and it did not came loose easily... looks like I need to remove motor cover. Is this right?
thanks!!!
KuRi
376
186
Spain
I answer to myself... YES, remove the motor cover and you will be able to replace the hose really easy. DO NOT try to use the old one as a full guide and attach the new one to the old one and pull the cable, bad idea xD (see my other post to know why).
It is very easy to remove the cover. The only trick is to remove the chainring first, it is just 4 allen screws that once removed will give you access to 2 more hidden screws of the cover ;)
554K
