Thanks.Whole set.
4 pot calipers need more oil to push the 4 pistons. 2 pot levers won't push enough oil as they are only designed to push 2 pistons.
What make and model of brake levers does it have because they might work fine with 4 piston calipers?Bike maintenance and understanding of components isn’t a strong point of mine.
Just got a 2022 Rise M10 and looking to change up to 4 pot brakes. Do I need to just swap out the calipers or does it need a whole brake set?
Thanks folks.
Deore M6100 levers and 2 pots calipers with 180mm rotors front and rear.What make and model of brake levers does it have because might work fine with 4 piston calipers?
Will work fine with, for example, Shimano BR-M6120 calipers (is what I have on my Trek Rail). Works best with BH90 hose.Deore M6100 levers and 2 pots calipers with 180mm rotors front and rear.
Great. Thanks for the help.Will work fine with, for example, Shimano BR-M6120 calipers (is what I have on my Trek Rail). Works best with BH90 hose.
What make and model calipers (2 piston?) are currently on the bike? Front and rear?Bike maintenance and understanding of components isn’t a strong point of mine.
Thanks folks.
Deore M6100.What make and model calipers (2 piston?) are currently on the bike? Front and rear?
Then buy a pair of MT520 or M6120 calipers (same caliper, whichever is cheapest) should bolt straight in and will transform your brakes (usually pre-bled but you might need to do a top bleed). After that as @steve_sordy says go to larger rotors.Deore M6100.
And no need for different levers?Then buy a pair of MT520 or M6120 calipers (same caliper, whichever is cheapest) should bolt straight in and will transform your brakes (usually pre-bled but you might need to do a top bleed). After that as @steve_sordy says go to larger rotors.
No.And no need for different levers?
