Hi,
EDITED POST :
Ep8 to Ep801 conversion done, SCOR 4060Z Darfon Harness/Battery
Update done, Everything works perfectly
Ep801 uses specific lockring that I didn't have to fix my chainrings.
EDIT : Ep8 LockRing Work on EP801...
In Short :
Darfon E4C0G-SN
SC-EM800
SW-EM800-L
Darfon E4C0G-S
Darfon E4C0C
You have to mod the Darfon Harness, as you see Ep8 and Ep801 power plug are different
Wiring
Small wire : Yellow to Orange wire.
I will update the post as soon as I have done several km
: If the motor is OEM (Factory Programmed) you may have an issue to getting it set to the correct wheel circumference, Local Dealer help needed or third party app.
I can't say at this time if the wire connection will support the power for long term, if not soldering may be necessary.
OLD POST :
Anyone know the wire correspondence between Ep8 and Ep801 ?
I plan to convert my EP8 harness to EP801 (DARFON HANRESS).
I already have a compatible battery, and the other components too.
So I bought a Shimano EP801 harness to take the connector.
To clarify :
Ep8 and ep801 use 2 power cables (black/red) and 2 thinner ones (blue/yellow), but their location changes...
I would like to know the correspondence for yellow and blue cable on ep801 motor plug.
THANKS
Darfon Harness
EP801 PLUG VS EP8 PLUG
(Only 2 of the 3 small EP801 plug are used)
EDITED POST :
In Short :
Darfon E4C0G-SN
SC-EM800
SW-EM800-L
Darfon E4C0G-S
Darfon E4C0C
Wiring
OLD POST :
To clarify :
THANKS
Darfon Harness
