eOne-sixty rear axle clamping torque?
6,854
5,302
12mm thru axle is usually 15nm .....see no reason why it would be any different on your bike
10,017
Thanks to both of you for your replies. :)
I had a figure of 10-12Nm in mind, but I wasn't sure (could have been 12-14Nm). I had to use something so I went for 12Nm. I will leave at 12Nm for the moment and I will spend some more time to try to get the figure from Merida.
6,854
5,302
That should be OK as an interim. As a bove my past experience for allen key thru axles has been 15nm for the rear and 10-12 nm for the front. That always seemed a little weird to me given the front thru axle is 15mm whilst the rear is 12mm but I suppose it could be because the rear supports 148mm width as opposed to 110 at the front.
577K
