EBike Tires for rocky down hill
Scoter
Hi Guys I’m the proud owner of a 2020 Levo Comp. Had for it for 6months and seem to chew out tires. Just wondering what you guys rate for the rocky stuff. As I’m looking for a new set and I see there are tires coming out specifically for the E Bikes ??
Mteam
1,864
1,801
gone
You don't need ebike specific tyres, but you do need strong tyres, so go for the downhill version of whatever tyre you prefer. My favourite is maxxis dhf doubledown on the front and maxxis Dhr ii doubledown on the back. They also do a proper dh version which is stronger again, but I can get away with the doubledown version.
The Flying Dutchman
340
556
Wellington NZ
+1vote for Maxxis tyres with DD (Doubledown) casing - only tyre that hasn't let me down.
Assegai up front for sure
in the back either a Aggressor for rolling efficiency, Assegai for pure grip and DHR for somewhere in between
nickfrog
139
75
I like the Eddy Current, despite being e specific. There is a deal for a pair on one of the German retailers site. It works out at less less than £80 delivered or so for the pair.
Gemini2k
66
28
Normal
Eddy currents are bad. They shed knobs like they’re going out of style. Just stick to the classics. They’re classic because they work. Dhf (or assegai) front, dhr (or high roller) rear. DH casing if you want. Everything else is basically designed to imitate these.
salko
1,274
865
SLO
I run MM up front and EC (with SG casing) on the rear, made more than 2kkm with both of them. MM is very good and grippy front tire, EC is good and durable rear tire in dry conditions, as soon as it gets little wet EC is not so good anymore ...
Ripping g
694
543
West yorkshire
Im running assegai front and rear on the levo comp carnt fault the tyre bags a grip were ever i ride the dont last that long specs on the rear but wow super grippy ??
nickfrog
139
75
IME EC are really good. Certainly never lost knobs despite the adverse terrain and my cavalier riding style. Far better than the DHF they replaced. In another league in fact.
neiloxford
120
82
The eddy currents do lose knobs when travelling at speed in the lake district after a few hundred miles, but I like them.
Mteam
1,864
1,801
gone
A lot of you seem to really like the eddy currents. I havent tried them , as I mentioned above I quite like the DHF/DHR combo, but I'm open to change if there's an improvement to be had without compromise anywhere else.
Are the eddy currents much slower rolling than the DHF/DHR combo? do you notice much worse battery life with them, or even rolling speed when the trail points downhill and you're not using the motor? In what way are they better than DHf/DHR?
They look like they'd be massively draggy, and v heavy .... dotn want my ebike any heavier than it already is (23kg) - without a very good reason!
wepn
The Barking Owl ?
Jul 18, 2019
1,006
1,145
AU
Assegai front & DHR II rear - Probably DD & Cushcore but possibly DH casing for maximum chunk - would be my recommendation.
Tyrrell
34
42
Dorset
My DHR11 lasted about 700 miles then the dreaded rip in the side wall, along with most of the centre knobs worn away to nothing.
My bike is a Haibike 8 Alt Mt weighs 28 kg and is de restricted, so the rear tyre gets a proper work out EC is the ideal Tyre For me.
Gemini2k
66
28
Normal
I dunno, maybe you’re not riding them very hard or on that rocky terrain or something? This is a pretty well documented phenomenon on the interwebz and anecdotally I’ve seen it on friend’s bikes. ?‍♂️
Doomanic
🛠️Wrecker🛠️
8,702
10,342
I've seen it (and done it) on MM on the rear but I haven't seen it on ECs. Yet. Mine survived 2 very hard days at Coed y Brenin with nary a mark though.
552K
