Ebike garmin mount
Mouse82
Great Britain
Hey so I have a Husqvarna HC4 and on the top tube there is a plastic cover over a circular hole, for which I believe could be used to house the power button/controls for a different model?
Now what I'm looking for is a replacement cap that doubles as a garmin mount. I'm not sure if something like this exists or maybe someone knows of a 3d printable file that someone has created.
Here's a few pics of said cap along with a mockup of what I'm aiming for
IMG_20241214_160217.jpg IMG_20241215_003357.jpg IMG_20241215_003401.jpg IMG_20241215_003411.jpg IMG_20241215_003416.jpg IMG_20241215_003513.jpg IMG_20241215_003519.jpg
Solution
I mounted a quad lock that way. I just drilled holes in the switch cover and the quad lock mount, and ran the cable ties through the holes. That way the switch cover sits flush in it's original mounting. Just have the cable tie clip underneath to hide them.
It's a very clean install. You can barely see the cable ties.
I guess if I was pedantic, I could trim the quad lock mount down, so it was more the shape of the switch cover, and get rid of the lugs. One day when I have more time I'll do it.
Astro66
Golden Boy
May 24, 2024
563
1,015
Sydney Australia
Solution
Mouse82
Great Britain
Ended up using the top half of a stem cap mount I had on my gravel bike, drilled holes and bolted the parts together, had to lose the bottom bolt as it fouled on the frame. So had to add some gorilla glue. Not pretty but is functional. Looks better once garmin is attached.
Thanks to Astro66 for the inspro! 🤘
IMG_20241219_161953.jpg IMG_20241219_162001.jpg IMG_20241219_162205.jpg IMG_20241219_162209.jpg IMG_20241219_162224.jpg IMG_20241219_162240.jpg
576K
