E8000 Display and motor connection issue
Jack AUS
21
34
I've got a Commencal with an E8000 motor. Have done a few thousand KMs and never had an issue until now. Went away for 6 months and went to start it and it doesn't start.
- Battery is charged.
- Replaced the on/off switch as I read they can go flat.
- Fiddled with the connection points behind display.
Took it into my local bike shop. They pulled the motor out and think it is an issue with where the display connects to the motor. They said if they hold the connection in place tightly they could get the screen to light up. As soon as they took the pressure off the connection it would die.
Has anyone experienced anything similar? I'm hoping for an easy fix. Thanks
Mart-e
92
52
Not sure of your residential placing but there is a motor tech service centre up on the Gold Coast..... eBike motor Centre.... they may point out a few examples to why cabling is causing a problem to fire up the motor....
No error codes on display is positive....
all the best mate!
John Beedham
73
54
Lochiel, NSW, Australia
Had a similar connectivity problem …. Appeared to be the cable with push-on connectors between the display and motor at the motor end. The connector wouldn’t click into place. Took to the LBS who Couldn’t fix the plugging in problem on the spot but suggested a thorough cleaning of plug ends and using the Shimano cable plug-in tool …. Black plastic that holds the cable end to enable a positive connection …. Fixed the problem for me
Jack AUS
21
34
Thanks John, exactly the issue I’m having. Appreciate the helpful advice.
576K
