e6002 Charging Speed Not Slowing Above 80%
nosenada
50
29
California
My e6002 charger charges my battery (504wh) at a rate of around 14% per hour all the way from 20% to 100%.
My understanding is that it was suppose to slow down above 80%, but it does not.
The only time it provides a slow charging rate is from 0 % to 20% (at a rate of about 5% per hour).
Is this normal?
urastus
⚡The Whippet⚡
May 4, 2020
1,548
995
Tasmania
Is this normal?
Yeah, this model charger is different to the other two available.
OldGoatMTB
423
253
27284
All I can say is that the charging on your battery sounds very slow! Mine charges about 30%/hour up to 80% and then slows after that. Above 90% I would estimate it's similar to what you say yours is charging at.
nosenada
50
29
California
My guess is that you have the e6000 charger not the e6002 charger. My post was about the e6002 slow charger.
My e6000 charger also charges at a similar rate of 34% per hour up to 80% then slows.
552K
