I guess the Hope 155mm cranks have persuaded quite a few Whyte owners to change cranks....primarily to reduce pedal strikes.
I stopped getting pedal strikes on my E180 once I learned to read the trail but it still does mean having to put in half pedal rotations more than I would like......so I became curious.
I have no such issues with the e160RSX.....both bikes have 165mm cranks....but the RSX is 29er which probably accounts for the difference.
So 155mm cranks for the E180 looked a worthwhile experiment......that is until I did more research!
Firstly the Hope cranks are too expensive for an experiment and I doubt they are any better than Praxis or Race Face Affect which are considerably cheaper.
Secondly for every 5mm cranks length reduction you really need to reduce the chainwheel by one size to maintain the same gearing.
Thirdly the shorter the crank the more power you have to input to get the same result in terms of trail progress/speed and pedalling efficiency is already not a strong point on the E180.
Lastly 10 mm is huge reduction when you consider what a 20mm diameter reduction means in terms pedal rotation circumference and that in turn impacts on weight distribution and balance when stood on level pedals.
So my conclusions are to try 160mm cranks probably by Race Face or Praxis , keep the same chainwheel and accept that I will need to be in 1 lower gear most of the time.
