E- thirteen front wheel play -bearing specs?
SteveSSS
75
41
Lancaster, UK
I have a 2019 Decoy CF Pro.
I have some forward/backward play in my front wheel (brake engaged) and some cavitation under braking, I presume the bearings have gone but I'm open to other ideas, as I'm not 100% sure.
If I need to replace the front wheel bearings, e-thirteen e-spec wheels. Do you happen to know what bearings I need, as I'm struggling to identify the bearings parts/numbers.
I've checked brake mounts, headset, forks / bushings and the plays is from the wheel but there's
no side to side movement.
Any advice, ideas and part numbers welcome.
Steve
Gary
Old Tartan Bollocks
10,496
10,702
the internet
Check your rotor is properly tightened to the hub and check again for play.
Worn hub bearings would not cause what you are describing.
SteveSSS
75
41
Lancaster, UK
Hi, yes I did this originally, all rotor bolt's and caliper mounts tight. As you've said I would of expected side to side movement for a worn bearing but there no play that way, just a couple of millimetres of movement front and back?
552K
