Gray squirrel
Experimenting with offset on 160 mm forks wondering if anyone tried the new e-bike fox work 36 how does it compare to the regular fox 36
In a good way or harsh way hopefully more precise steering feelThe ones i have ridden definitely feel stiffer.
I was just on website says 38 44 51 e-bike ?I call fox Monday ?I was just on the Fox dealer portal and all off the Ebike specific 36s are listed at 51mm
What are you recommending for your levo costomers if they upgrade to 160 go with e-bike specific or standard 36?I was just on the Fox dealer portal and all off the Ebike specific 36s are listed at 51mm
I have a transition sentinel with 44 offset but have not compared on same bike back to back I know all the fact about differences thicker stanction,solid crown etc but I wanted to see if anyone did back to back runs to feel itThe Eeb 36 is just a 36 with thicker stanchion walls and 34 internals so in all aspects other than stiffness comparing it to a 34 makes more sense.
don't worry about offset. it's just this/last years purple
I own 7 mtbsI have a transition sentinel with 44 offset but have not compared on same bike back to back I know all the fact about differences thicker stanction,solid crown etc but I wanted to see if anyone did back to back runs to feel it
Standard, it’s just less complicated when it comes to buying internals for rebuildsWhat are you recommending for your levo costomers if they upgrade to 160 go with e-bike specific or standard 36?
Ty ?Standard, it’s just less complicated when it comes to buying internals for rebuilds
Sort of, yeahIt seems to me that the new Marzocchi Bomber is the same as the EMTB versions of the 36 in terms of extra material, or is it actually different? I.E its marketed as being stiffer than a 36 with more material in the crown and stanchions. Basically the same fork?
