I did, but to make space you have to replace the e8000 mode changer with an e6000 one.
Shimano Steps Switch for E6000 - SEIS Compatible | ELECTRIC BIKE SPARES | Evans Cycles
I used one of these, but didn't like it mainly because it took too much effort to operate, so I put the original back on but on the right hand side of the bars and tend to operate with the palm of my hand rather than my thumb.( both my thumbs were damaged in a motor bike crash many years ago and have remained weakened ever since).
Brand-X Ascend Lever Kit V2 - (1 x Gears) | Chain Reaction Cycles
I would try one of these for better leverage if I could convince myself that £50 wasn't a bit of a rip-off.
Manitou Jack Dropper Seatpost Trigger | Chain Reaction Cycles
Thanks for your reply.
So you currently used the standard Focus fitted one?
I was going to change the mode changer as well, is the Brand-X lever easy enough to fit?
Yes, I have refitted the original one which I have now got used to.
The Brand X is easy enough to fit and is reasonable quality, it just didn't supply the leverage I was expecting.
I use the standard dropper post switch and the standard mode shifter and to me they are both absolutely fine, no need to change them to me
Do you have the same dropper switch as in my picture?
The exact same switch
It's not just you, the short lever takes a lot of effort to operate. Similar designs but with longer levers, like HPRs, are much 'lighter' to use.Perhaps it's me then...
E7000 shifter and Pro lever
I think so, when setting up we used the shifters to scroll through the settings, I haven’t had a good play with it yet but I’m sure it works like the normal shifter set up.Raxor
Does the E7000 allow you to scroll through the screens on your display remotely?
Andy probably rips up old Yellow Pages with his bare hands as a hobby.
actually I do understand the reason why people change both switches on the Jam2 for me I have got used to how they are but I think that I would really prefer them both changing but I am not great with bike DIY and I would feel a bit daunted about getting it wrong, but the dropper post switch is certainly an odd operation and I would love a normal one and probably the mode shifter as well but can I do that without messing it up Is it easy enough to do for a novice?
It's fairly straightforward if you run the new cable externally along the bars.
If you run it internally, as Focus do, you may have to drill a small hole in the bars which I did.
So you just unplug the old one and plug in the new one? Any software issues?
Ahh I don't like external cables
Another question...
As for the dropper switch I presume you just use the existing cable?
I'd use the external but put a new internal cable in, mine has a small hole to tread the cable through which you fix with a crub screw, I'm actually going to replace my inner as its frayed at the lever and i'm thinking of putting a shimano inline adjuster in the line for more adjustment options.
