Chocolatelegs
What chainring have people fitted to the Levo Gen 3 ?
I have a Gen 3 Comp alloy, Long story short I snapped my standard NX chain, replaced chain with a X01 correctly sized. Slipped under load in turbo on first test ride so replaced the XG 1275 GX cassette. Rode lovely, thought I might aswell change the front chainring then the whole drivechain is replaced in one go.
So I ordered up the praxis 36T Ering same as I done on my Gen 2 Levo to gain bit extra use of the gears.
Ordered the lock ring tool too, got around to fitting it yesterday (bikes been un ridden since)
Fitted the praxis 36T Ering with the correct bolts as these are threaded and the sram xsync2 was nut & bolted. Took my chain guide off all looked good.
But I’m having a hellish time getting the gears to shift correctly.
Checked limit screws, checked b tension with tool, checked cable. Seem to get it to shift nice in the higher gears (small cogs) but after half way up the cassette it all starts misshifting and jumping around. Only thing that I can see reading online maybe the chainline has been changed with the praxis ring ??
Any ideas of what to look at, only other thing I can think is to swap the chainring back to identify if it’s back to working 100% to rule out bent hanger or mech etc
Sorry for long post
Sorry for long post
