Crossroads Rail
I will be changing from sram eagle to shimano 11 speed when my eagle cassette is done...at 5000 miles it’s still working from running 3 waxed chains?!
Can anyone tell me if the drive side axle end cap (12mm shaft, boost) on the sram cassette will fit the Shimano 11 speed I’m going to fit? I suspect not having found what looks like the right part on the trek web site....but to be sure before I spend the £12.
I wonder if the eagle shifter will also work, obviously with an empty click at one end? I would be looking for a shimano derailleur as well to shorten the cage length.....although would the sram derailleur work?
Any pointers welcome thanks.
