Does anyone know if a 38t chainring will fit on 2023 Cube 140 AT
lawsons2bad
Poole, UK
Hi Does anyone know if a 38t chainring will fit on 2023 Cube 140 AT medium frame, i am mostly riding on the last 2 or 3 sprockets and am hoping to fit a 38t chianring so i can use more of the cassette, i have seen posts where people have fitted 38t chainrings on the 2020 models without any problems but cant find any posts of 38t chainings on the 2022 models on.
alancube
55
24
Essex
Last couple of days saw me fitting a 38 tooth to my Cube! Gets close to the frame but clears it ok. Mine is a medium frame with 29 inch wheels so was fitted with a 34 tooth.
Like you it will enable use of the larger gear on the cassette. 1707334628313_IMG_20240203_115549674.jpg
lawsons2bad
Poole, UK
Thank you so much and yours is the 2022 model and on?, so glad you replied because mine is on order and i was a bit worried it would fit, my bike is the 2023 140 Action team, i bought the same as you but i bought the Aluminium one, BTW did you have any trouble with the chain or did it fit straight on without any problems?
alancube
55
24
Essex
No probs, I did think I would have to add some chain but it seems fine, still plenty of spring in the derailleur mech when on the largest gear.
Only had mine 6 months and looking forward to using all the gears!
Mines a
Cube Stereo Hybrid 140 HPC Pro 750​
554K
