Do you top up your battery before rides?
shredjim
36
19
White Salmon, WA
I have read that ebike batteries count charge cycles in the battery health metrics. I normally place my bike (M10) on charge a few hours after I ride it the same day I ride it - and let it charge until the light turns green. Then the next time just before I ride it, I put it on charge to make sure I have every bit of charge available - since the battery is not that big, and I have ran it out one time and have had the red light on 3 times. My top up timeframe usually is 5 - 10 minutes. I often ride with guys with fat bikes with bigger batteries, so I need to be conscious of these things and want to begin every ride with a full battery. What is the opinion on this, is it best for battery to top up, or not? Does the top up count as a charge cycle?
Gyre
630
422
Pasadena, CA
In terms of the cycle count managed by the Bosch firmware, it supposedly accounts for partial charge/discharge cycles so whether you top up or not, it shouldn't change how quickly you accumulate cycles either way. For a Shimano EP8 RS, I don't know how it counts cycles, but I would hope it's smart enough to do the same.
In terms of battery chemistry, the battery will last a little longer if you avoid deep discharges or max charges. Floating in the 20%-80% range and storing it at ~50% is generally a good rule of thumb. That said, you bought it to ride it and the battery will ultimately degrade over time regardless of how carefully you baby it.
Agree with storing the battery at around 50%, the battery aging accelerates if it is discharged or fully charged. Charge it the night before you plan to ride.
Fun fact - some batteries (in drones for example) have an automatic discharge function (to half full) that is engaged if they are not used for around a week to prevent aging.
559K
