That's definitely how they're supposed to work, but some seem a bit better at it than others.I was shortening my front brake hose last night after getting some more olives / barbs.
Whilst doing this, I had the caliper off, and gave it a good clean out with Wurth brake cleaner, and using my new brushes that I bought from Amazon for pennies!
I then folded up a rag, and ran it back and forth through the caliper.
I've never considered lubricating the calipers, as I always assumed they'd be self lubricating with the brake fluid that's pushing them out each time I pull the lever?
Yes....but mostly the rear brake since the front brake orientation behind the fork lower means it is better protected from mud and dust.
I use a calliper block that allows only one piston at a time to be extended and clean the piston with IPA and a cotton wool bud. Then lubricate with dot 5. Once all pistons are cleaned and lubed and pushed back, I clean the calliper with IPA.
All my brakes are Code RSC.
I totally agree this. I was so tired to clean pistons almost every week or even day at Alps this year and changed the brake to Shimano XT and sold the Code RSC.When I had Code RSC I did this regularly as it was the only way to keep them feeling nice. Not something I have done often with other brakes unless they are disgusting. With the Codes, I used a little 3d printed template my friend lent me. It allows you to expend 1 piston out at a time without it coming totally out. Then I would clean with IPA (not Brewdog!) and lube with the SRAM brake fluid. Tedious, but it did help. RSCs in perfect health are superb, they just seem to take a lot of faff to keep them feeling nice.
Every once in a while, I use the Birzman piston spreader and Muc-off silicone spray.So do you clean & lube your disk brake pistons? If you don’t then why not? If you do what gear, greases, lubes etc do you use?
No, not as routine maintenance. They don't need maintaining. Do you maintain them on you car?So do you clean & lube your disk brake pistons? If you don’t then why not? If you do what gear, greases, lubes etc do you use?
On hi performance brakes you do need to clean and maintain them. The don't have dust seals and experience extreme conditions just like my bike brakes.No, not as routine maintenance. They don't need maintaining. Do you maintain them on you car?
^^THIS!I clean when I change the pads, I use soapy water and a toothbrush
Over time the seals go hard and the pistons stick, the only solution is to replace the seals.
You can't replace the seals on Shimano brakes. They don't sell them.^^THIS!
I can tell you there is a LOT of sketchy info in this thread... I've wrenched bikes for over 30 years and here is my take:
Most brakes are fine with doing just what Goff does. Sram brakes are prone to the sticking piston issue, near as I can tell, because of seal/piston tolerances. Their phenolic pistons in their RSC versions are just as bad so we know it's not due to piston expansion. At some point I'm sure they will get it resolved but it has been an issue for a while now.
Whoever came up with the "use the same fluid on your pistons as a lubricant" thing is... I'll just use the word "misinformed" as all that will do is attract dirt and wear your seals faster. I don't use any lube except for with problematic Srams and then I will only use silicone like the Permatex red. 2WheelsNot4 got that one right because it won't degrade the seal material. Do NOT use isopropyl alcohol (IPA) to clean the pistons with the seals in place because it degrades seals (ESPECIALLY the 99% version). If you can't get the pistons clean with soapy water then you've likely got seal degradation onto the pistons and your best bet is to remove the pistons, NOW clean with IPA, replace the seals and re-bleed.
Have FUN!
G MAN
So what would you clean with after a bleed? Will soapy water be enough?^^THIS!
Have FUN!
G MAN
I spray them with brake cleaner, then I put some brake oil on cotton ear pads and lube them.So do you clean & lube your disk brake pistons? If you don’t then why not? If you do what gear, greases, lubes etc do you use?
would you be so kind to share this 3d model?When I had Code RSC I did this regularly as it was the only way to keep them feeling nice. Not something I have done often with other brakes unless they are disgusting. With the Codes, I used a little 3d printed template my friend lent me. It allows you to expend 1 piston out at a time without it coming totally out. Then I would clean with IPA (not Brewdog!) and lube with the SRAM brake fluid. Tedious, but it did help. RSCs in perfect health are superb, they just seem to take a lot of faff to keep them feeling nice.
