A point to note for Levo owners. The front wheel through axle has a qr lever which has to be set at the right tension to secure the front wheel in the fork. If/when that lever no longer function ss it should it needs adjustment and that is done by using an allen key in the centre of the axle and adding 1 or 2 clicks by turning clockwise. BUT the allen key size is 2.5mm and is not part of the multi tool. So just a heads up here to make sure you carry one because removing the front wheel for a puncture repair and then not being able to properly secure the front wheel is not a nice way to ruin a ride.....or if like me you remove the wheel for transportation and you cannot secure the front wheel, the ride cannot even start!
