DIY Carbon Build F-150
Chickon1
62
32
FL
Thought I would take a chance with this company since I really like the specs on the frame. I have purchased other chiner carbon frames and the quality is about the same from a reputable place. Not great but not horrible. I had a few issues with some of the specs.
Issues I had with it.
Rear shock is a trunnion and they said it wasn't when I asked
The headset fell apart when installing it.. kinda expected I guess
Zero directions.. Not a huge deal
16mph speed limit on the motor
Shipping took around 3 months.. battery another month.. can't really complain to much in this environment
The frame suspension hardware is low quality
The Good
Geometry is really nice
Carbon quality seems good
No issues with alignment on anything
Motor firmware seems good and very quite.
Finish was pretty good. Didn't take much sanding
patentguy
11
Florida
Hi- am thinking about getting this same frame. Do you still like it? The only frame I can find that accepts a 180mm front fork, 27.5. All the other e-bike frames I could find only recommend 150mm front fork max.
What battery does it use?
Thank you.
552K
