Decision to buy a ebike: Cube One44 HPC TM or Amflow PL Carbon
turandot
Spain
I have doubts about deciding on one of these two models with all their differences:
- Cube Stero Hybrid One44 HPC TM
- Amflow PL Carbon (800Wh)
By specifications I would buy the Cube, although by weight I would buy Amflow, there are 3 kgs of difference between one and the other. The advantage of the Cube for the removal of the battery: best for transporting in the car and charging only the battery at home.
Model: Cube One44 HPC TM vs Amflow PL Carbon
Brand: Experienced vs New brand
Support: Experienced vs New brand
Weight: 24.1 kg vs 21.1 kg (M)
Engine: Bosch Gen5 (85Nm) vs DJI Avinox Drive (105Nm) 850W
Battery: 800Wh (Charger 4A) removable vs 800Wh (Charger 12A) none removable
Rear shock: Fox Float X Performance (140mm) vs FOX Float Performance (150mm)
Fork: Fox 36 Float GRIP (150mm) vs FOX 36 Performance (160mm)
Brakes: Magura MT7 vs Magura MT5
Rear Derailleur: SRAM GX Eagle AXS vs SRAM GX Eagle
Shift Levers: SRAM AXS Pod Controller vs SRAM GX Eagle Trigger Shifter
VWsurfbum
🤴King of Bling🌠
Jan 11, 2021
1,561
2,305
England
That's a tricky one for sure, is it your first Ebike?
Do you have dealers of both near you?
Personally I would want to try both and go with the one that fits my style of riding best (they're both quite similar) but could ride very differently.
562K
