Decathlon E-ST500
20,749
A bike which I'm sure is on most people's list along with Levo's, Decoy's, Mig-R's, Powerplays ... E-ST500 ..
Shortly after heading back into the world of cycling with a cheapo MTB, I found there was no way I could keep up with the Other Half on horse back going up the hills, so took the next step - "Cheap" emtb ...
€1200, which in my mind seemed like a crazy amount of money for a €400 bike with a €30 motor stuffed in the back wheel.
Ordered on line and collected it from the local Decathlon. Was slightly disappointed that it already had some dinks and scratches from delivery and the tyres looked like the shop had given it a fairly thorough test ride, but heck, I'm sure it will have more scratches soon with my inability...
First impressions : it was amazing. Felt so much better than my cheap mtb and with the motor I could at least stay near the horse, as long as they didn't go too fast.
It's described as having a torque sensor in the crank. It's actually a pedal movement sensor that just reads when the left pedal passes the top point (TDC?). So you don't get varied assistance, you get either no assistance or full assistance. This can catch you out a lot at the start if you're in a higher assistance mode as you set off, or if you're trying to squeeze through a gap as the motor keeps pushing until it realises you haven't made another turn of the cranks. As a newby, it's easy to flip over backwards on steep inclines with instant full power and a lot of the weight stuck in the middle of the back wheel.
Two days later it stopped working on the way home, (only dry rides and not washed at this point) so I experienced my first of many "Heavy workout" trips home.... Tried all sorts of resets, battery removals etc .. nothing.
The next morning I cleaned it to take it back.. bounced it up and down to shake off some drips and then gave it one last try .. it worked ..
A few days later it stopped again .. The return to store to fix option seems to involve it being left for a day or two and which point moisture in the crank sensor area drys out and it fixes itself.
Eventually, I got fed up and they said they'd have to send it away to fix it properly, which involves packing grease in the crank to stop water getting to the sensor. This would take 2-4 weeks ....
So after a couple of weeks I was hoping to get my bike back or at least get a time scale. Another week went by with no information. Eventually I had an e-mail explaining what they would do to fix it, it would be done as a priority and it would be back on Friday - guaranteed...
End of Friday, went to the shop .. no bike. The guy in the shop checked their system and confirmed it wasn't back, wouldn't be back and hadn't been looked at yet.
By now I was fed up from 4 months of intermittent bike, no bike for 4 weeks and a lack of information. I'd lost confidence in the bike and the service, so the next day I went back and asked for a refund.
To their credit they stuck to their "12 months not satisfied and you can have a refund" and I got my money back.
A couple of weeks later I was back in there buying something else and saw my bike was back. It was for sale as a new bike. I knew it was mine instantly as I'd worn some paint off the seat stay with my heel, so there was an oval white area. After seeing that, I suspect that my bike was already used when I bought it and had been returned by a previous dissatisfied customer suffering from the moisture problem. It would explain the scratches, dinks, dirty tyres and stopping from the moisture issue when it had never been wet.
So all in all .. as a "cheap" bike for use in the dry on fire roads and tow paths, it's actually not bad, but I think there are other better offerings out there for similar money (Focus?). From what I know of geometry (not much) it's a bit of a contradiction. It seems both twitchy and difficult/slow to turn. Compared to it's replacement, it wasn't overly confidence inspiring and the standard tyres seem to release a special teflon compound in the wet. It's got a comfortable saddle and I think anyone buying one now would have the fixes in place as standard so shouldn't have the moisture/sensor problems.
The customer service in the shop was always excellent, but behind the scenes was lacking. It seems a bit dodgy selling used bikes as new bikes in my mind, but maybe that's normal ?
I then test rode a mid drive Shimano E8000 bike - this felt like 20 years of evolution in every way compared to the decathlon. Unfortunately, it had also suffered from 20 years financial inflation compared to the decathlon which required 20 years of promised slavery to the OH for agreement to purchase. :)
Decathlon have a mid drive brose E-ST900 (also a hardtail) out soon with hydraulic brakes (for some reason the e-st500 has cable disks which feel horrible) and better forks for about €2000. That shouldn't have the same issues in theory.
khorn
980
1,055
Denmark
Well written story and it underlines the fact that you usually get what you pay for. Sometimes it is just too expensive to buy cheap, I strongly recommend that you stick to a mid drive setup with a known brand engine. Right now there are good offers on the 2019 Levo HT even some of the stuff is quite cheap then to motor and battery is a very well known setup and you can always upgrade as you go along. I got my wifes Levo HT locally and paid 2100 Euro for it, not a bad prize.
Karsten
Snoozeboy
104
56
Lausanne
I was going to buy an st-500 for the missus, but in the end, spent another EUR 500 or so on an entry level ht haibike with a mid drive Yamaha. I don't think I regret my decision.
jerry
257
166
Belgium
Got quite a bit of experience with Decathlon stuff, from the early days of my biking. I still have a 26'' Rockrider 8.1 that I occasionally use abroad; I cannot fault it - thrown everything at it I could physically manage (including the likes of Roc d'Azur), never disappointed, never failed.
The problem you described is a known issue, in France bikes have been recalled.
If ever you'd consider DCT - be it bikes, but certainly clothing etc... the key is - buy their absolute top-of-the range stuff, and you're good. This will mean it will at first sound quite expensive for a "supermarket" product, but you'll have value for money. The upcoming e-ST 900 (with Brose motor) seems like a fair deal (Nevertheless, wouldn't buy a Gen-1 product of theirs though. Wait until they ironed out the FAF's (frequently encountered faults)).
DCT has the (marketing-wise silly) approach to come in at the low end - whereas premium manufacturers will want to come in at high end, and only after making $$$ from early adopters, drop down towards mass budgets.
jerry
257
166
Belgium
Rockrider 8.1. 3x9. Must be about 15 years old now. Enjoying its retirement in Turkey (this is Lamos Canyon, Mediterrean coast). The construction on the handlebar is a GPS-holder that was getting attention at the time (RAM mount- or something?).
20,749
Don't get me wrong, I have nothing against the Decathlon gear. I bought two rockriders a couple of years ago for friends and they've been faultless. Just bought 4 lightweight running tops for €4 each to wear under my armour after spending hours searching the net for similar things at ten times that price.
As I said, I'm sure the ST-500 will be a great bike for a lot of people. If I'd not had problems with reliability and then repair times and poor communication, I'd probably still be riding it quite happily now.
As Karsten said, sometimes it's too expensive to buy cheap and if I'd have had the opportunity to ride one and then ride a mid-drive I'd have gone for the more expensive mid drive like Snoozeboy.
There are always compromises in anything, when the compromises involve parring down the price and components to the bare minimum, sometimes what you're left with might not be what you were designing. I'm not sure if they didn't do enough testing or if they made last minute changes based on component availability or pricing, but for a large experienced company they made mistakes I wasn't expecting.
552K
